09-29-2022 03:48 PM
I'm using the Sigma 150-600 Contemporary with an EF-R adapter on my R5 and R6. It worked fine, until I upgraded the camera firmware to the latest version. Since then, I get an Error 01, "Communications between the devices is faulty. Check the camera, lens, or mount adapter contacts".
I have tried cleaning all the contracts with isopropyl alcohol.
Has anybody encountered this problem? Will upgrading the lens firmware solve the problem? I would have to purchase the lens dock to do this.
10-01-2022 10:46 AM
"I have tried cleaning all the contracts with isopropyl alcohol."
Stop doing that, it very rarely to never helps and can make things worse. Much worse!
"I'd contact Sigma to see if they are aware of the problem and have a solution."
I would too. Canon does not make their cameras work with off brand lenses. It is up to the lens maker to make sure the lens works on a Canon body. I think this might be an ongoing problem as I have heard of it from several different people.
As to the Sigma dock, I would buy it, I did. It is of little use 99% of the time but when you need it, it is a nice to have unit. It isn't expensive. If it were much more expensive I would advise you don't need it. Sigma used to, they may still do so, update your lens FW for free. But you have to send the lens to them. A hassle, expense, for sure that the dock eliminates.
10-03-2022 04:38 PM
I’m using Canon’s EF-R Adapters, the ’plain’, basic one in my R6 and the Control Ring Adapter on the R5. Same problem with both.
10-03-2022 04:39 PM
Can you point me to somewhere that explains how to save your configuration to the Custom Settings and putting it back? It’s not something I’ve used before.
10-03-2022 04:46 PM - edited 10-03-2022 04:47 PM
I’ve generally always used Canon’s lenses and accessories until I got the Sigma 150-600 and the 18-300 for my 80D. Which non-Canon adapters are recommended? They all seem to be brands I’ve never heard of, except for Neewer.
10-03-2022 04:55 PM
I recommend only Canon adapters, and they are the only ones that Canon supports - which does not imply they support third party lenses attached to them. So far, I have tested about 29 Canon lenses using their adapter and had no issue.
10-03-2022 04:57 PM
It's in the camera manual. That should be your first port of call for any questions about how to use the camera
10-03-2022 05:09 PM
“I recommend only Canon adapters, and they are the only ones that Canon supports - which does not imply they support third party lenses attached to them.”
Of course, I totally agree with that recommendation. Like I pointed out above, if you are using a third party mount adapter, then the odds are high that is the issue.
10-07-2022 10:11 AM
Actually my first response is an internet search. I have the manuals on my iPhone and iPad, but there are often more specific instructions online. Such as:
https://support.usa.canon.com/kb/index?page=content&id=ART133259
10-07-2022 10:12 AM
I read that the other way around somehow. I do use Canon adapters.
10-07-2022 02:58 PM - edited 10-07-2022 03:03 PM
Re: Can you point me to somewhere that explains how to save your configuration to the Custom Settings and putting it back? It’s not something I’ve used before. and Actually my first response is an internet search. I have the manuals on my iPhone and iPad, but there are often more specific instructions online.
In this case the manual clearly states how to save configuration settings, and I then wonder why you asked us to tell you where to look for the information instead of doing the search within the PDF's yourself.
