Shutter Speed
belladeutsch
I have the Canon RF 24-70, f2.8 L IS USM lens.
I shoot in manual, but I find I cannot go higher than 250 on the shutter speed. Any ideas why this is so?
4 REPLIES 4
Stephen
Moderator
Moderator
Hey there!
Which camera are you using?
Canon R5
There are  two possibilities:-
  • You have a Speedlite on the hotshoe and it is switched on. This limits the shutter speed to the camera's sync speed which is 1/250, unless you use high speed sync mode.
  • You have configured the custom function for Set shutter speed range - it's on the C.Fn2 menu page. If there is a blue star next to the entry on the menu there's some limitation set.
Brian
Thank you, I will check.
I have a trigger on my camera for a strobe. Can that be it?
Avatar
