09-06-2016 02:58 PM
I have been using a Canon Rebel T5 recently & I am not sure if the settings are incorrect or if the blurriness is due to camera shake. Would someone be able to tell me just by looking at one of the pictures? I am new to this, so appreciate any help. Thanks!
09-06-2016 03:37 PM
Thank you so much, I really appreciate all your help!
09-06-2016 04:41 PM
I saw this a bit late but I'll add a little bit on what others have said. Not sure what mode you used to take this picture but there are a few things you could have chosen to improve the picture.
You shot at 1/200 with flash on (my guess is the built-in flash). With the built-in flash, you can't use high speed sync so the fastest is 1/200 for this camera. At FL 18mm, 1/200 is plenty fast and I don't think this is a problem. Even though I shake a lot, 1/200 never causes me any problems. However, your ISO was set to 800 while your f/stop was set to f/14!
f/14 is totally unnecessary here. As a matter of fact, it contributes to your picture being not as nice as it should. Beyond f/11, many lenses start to exhibit sharpness degradation due to diffraction error so unless you have to, try not to go beyond f/11. Since this is a person's picture (i.e portrait), I'd shoot this at f/2.8 or f/4 for nicer background blur. If you have shot this at f/4, your ISO would be very low like 200 or something instead of 800. For this camera, ISO 800 starts to show noticeable degradation in IQ, imho.
For this particular picture...tough lighting, ISO 800 and f/14 all contribute to the picture not looking as nice as others with more optimum settings.
09-06-2016 04:44 PM
Thanks so much! I was in Portrait Mode and thought their default settings would be OK - I will set the settings manually in the future and see how it turns out.
09-06-2016 05:49 PM
According to your EXIF data...
Camera Model: Canon EOS REBEL T5
Lens: EF-S18-55mm f/3.5-5.6 IS II
Image Date: 2014-02-05 04:04:25 (no TZ)
Focal Length: 18mm
Aperture: ƒ/14.0
Exposure Time: 0.0050 s (1/200)
ISO equiv: 800
Exposure Bias: none
Metering Mode: Matrix
Exposure: Portrait Mode
White Balance: Auto
Flash Fired: Yes (Auto, return light detected)
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
Software: Windows Photo Editor 10.0.10011.16384
I'm surprised to see that shooting in "Portrait" mode sets the aperture to f/14. But as already mentioned it's trying to compensate for the high ISO and strong backlighting. Usually, auto "Portrait" mode settings will try to keep the aperture opened up to keep the subject in focus and throw a bit of blur into the background to make it less distracting.
Next time try switching to AV mode, zoom in to 55mm, open the aperture to f/5.6 and maybe cut the ISO back to 400 or 200. Try to find someplace with more even foreground and background lighting. Move in closer to your subject and turn off the flash. Keep the background uncluttered if possible. You should still end up with a shutter speed that will allow you to shoot hand-held. Post a couple sample shots here and we'll take another look at your results.
Oh... And you should probably set the clock and calendar on your camera. ![]()
09-07-2016 11:09 AM
LOL! I told you I was helpless. I will absolutely take everyones' tips into account when we do our next photo shoot & will post a picture of the (hopefully) crystal clear final product! Thanks again for all your help and time on this, what a great resource this site is!
09-07-2016 02:52 PM
Nah... You're not helpless. Helpless would be trying to shoot with the lens cap on. You're just a little overwhelmed by the upside of the learning curve. ![]()
09-08-2016 10:17 AM
Ha, I'm certainly guilty of having done that as well!
OK, after taking all your tips into consideration, we used AP mode for the latest shoot. Since it was cloudy, I turned the ISO to 400 & played with the different f-stop settings you all had recommended. My face is looking a lot clearer. I am happy with this, but will still edit with the saturation & brightness. Any other recs? THANK YOU!
09-08-2016 10:22 AM
Nice. Actually, I have taken some of my best photos on brightly overcast days. The clouds act like a giant diffuser, which tends to eliminate any parts of the photo from being overexposed, or frequently underexposed.
09-08-2016 10:24 AM
We are going to try and shoot on cloudy days (not difficult in Chicago) since it does seem a lot easier.
You guys are all great - I am sure I will be back, LOL!
09-08-2016 11:32 AM
@Waddizzle wrote:Nice. Actually, I have taken some of my best photos on brightly overcast days. The clouds act like a giant diffuser, which tends to eliminate any parts of the photo from being overexposed, or frequently underexposed.
Even a white sky is vastly underrated. I've found many occasions when a white sky worked better than a blue one would've.
