SFTP with Canon EOS R5 Mark II
pedz
Rising Star
Rising Star
I've tried to set this up for the past hour or so.  I can not even get the camera's MAC address to show up on my arp -an output.  Is there a way I can configure the local network and test it out to make sure the password is correct before moving on to the FTP (or SFTP) set up?  Right now, the only thing I get is that it can not connect to the FTP server.
I have not set the root certificate but I assume that is ok.
I setup a Comm and then set up a Function and then go into Connection Settings and create a "set" using my home network and Mac server.  I noticed in the manual that only Windows is supported but that doesn't make any sense to me so I just assumed it was an error.
14 REPLIES 14
You could give FileZilla a try as the server on your Mac. It's free and supports all three capabilities, FTP, SFTP and FTPS. I have used it in the past on a Mac with an EOS 5D Mark IV, but not in recent times. If you havent already implemented some FTP server the camera won't connect to it.
I am not able to help on the packet sniffing results as I don't understand much more than what packet sniffing is.
The grips that exist to add additional network capabilities to the EOS R5 / R5 Mk2 but also add a wired gigabit port to them. This is often the preferred connection for professionals at large sports events where wireless signals are not reliable enough.
In my experience a good quality card high speed reader connected to the Mac USB4 port is still the fastest way to move large amounts of data to the computer. I have tried a few different SD UHS-II and CFexpress readers and there are some that are fast and many that are not so fast.
Brian
Brian,
Great suggestion. I was going to recommend filezilla next. It can be configured for SFTP and FTP..  I don't know if it supports FTPS, I've never tried but I do know that you can load certificates with it as well.
@pedz,
I would think you'd be able to see packets with Wireshark.  It sounds like you understand the process. Connect the camera to the same network as the system running the FTP server.  Point the camera to its IP address and listening port.  Supply credentials.  So that's not working, huh?.
I've never tried to ping my camera when it's connected to my wireless network. Can you try?
One of the reasons why I've never pursued this is  I'm not a professional in the field needing to get my pictures to a publisher or editor as soon as possible.  Canon has their professional apps for that which can be used on mobile.  I also know that a wired connection is 10x faster and much more reliable.
Brian.  I appreciate your additions. I've never used FTPS and a certificate only SFTP with a private key.  Thanks for setting me straight on the FTPS protocol.
pedz
Rising Star
Rising Star
Another factor in this is Canon now has the ability to set "Priority" on the card selected.  For me, this is a BIG win.  There have been three or four small "favors" that Canon has done with the Mk 2 that I really appreciate.
With the R5, when the CF card was ejected, the camera would switch to the SD card when the card door was closed and not switch back automatically when the CF card was later reinserted.  Now with "Priority" set for the CF card, the Mk 2 will switch back when the CF card is put back into the camera.  For me, removing the card and using a reader to transfer files is going to be faster and probably simpler.  If I thought I would use networking extensively then I would dig back into this more but I just don't think I will.  If I could capture packets on my router (my Wi-Fi hub), then I would analyze this to death.  That's my nature.  But I'm stymied trying to figure out how to capture all of the packets the camera may be sending.  I've never snooped Wi-Fi before.  The doc says that if the network is not "protected" (i.e. not with a password), then I can see all the packets so I'm tempted to set up my guest Wi-Fi just to see, experiment, and piddle with this.
In a past life, I was on the customer support team for networking at IBM.  The fact that I don't see any packets coming from the camera to the server with SFTP leads me to believe that there is a significant bug in the current implementation.  Also, with regards to pinging the camera.  Yes, the camera does ping.  I don't recall the specifics.  I believe it does not ping until the transfer is attempted as oppose to when the "CONNECT" is done on the camera but I was not paying careful attention.  I do remember the ping would start and then stop and then start again but I didn't really characterize it precisely.
I feel your pain, Pedz.
I'm also on Mac, and after a very frustrating afternoon, I can confirm that the R5 Mark II’s SFTP function is NOT working for me either.
I have my own Linux server online, accepting SFTP traffic via the default port 22. Ideally, SFTP should allow us to transfer proxy files overseas privately.
  • Port 22 is open (confirmed with nc -zv),
  • SFTP login works fine with a desktop client,
  • Permissions are correct (folder set at 0755),
  • Credentials and settings are verified,
Yet, the R5 Mark II keeps throwing error 41, failing to connect to the SFTP server via SSH.
I run multiple servers and am no stranger to SSH. I’ve checked and validated my credentials, server IPv4 address, (disabled IPv6) and router settings multiple times. I’m 100% sure my server isn’t blocking SFTP traffic on port 22—there’s no firewall interference.
Interestingly, my router detects the R5 under Murata Manufacturing Co. Ltd. with the correct MAC and local IP address, so the camera is at least connecting to the network.
I’d love to hear what Canon support says if you manage to get this working.
Best,
BL
After some thought, I gave up.  There is no way wireless SFTP is going to be fast enough to be simpler / better / faster than just pulling the card out, putting it in a reader, and transferring the files to the Mac.
If you recall, when you first connect to a new server (new server as viewed by the client), there is a warning that comes out that the true identity of the remote host can not be assured.  This can be avoided by using "ssh certificates" but the monkey business needed to get that to work I don't 100% recall and I don't see a place to add the "ssh certificate" to the camera.  Plus (it has been a while so I may be mistaken), if you put the server into debug mode, it does not get up to the point where the host validation is occurring.
At the time I had several disadvantages.  My Wi-Fi and router was on a device I could not log in as root so I could not see all the network traffic.  The Mac had a bug in it at the time where sharing its network connection was not working (according to the net and according to my attempts to get it working) so I could not make my Mac be the router.  This would have allowed me to see all of the network traffic which I was not able to do capturing packets just on the Mac.  As I recall, I concluded that the camera was not getting the IP address of the server because the SYN packet to the server from the camera was never captured.  Again... its been a while so my memory of the details has been lost so take the above with a bit of skepticism.
