Returning raw files to eos80d
Paul5228
Hello friends. I would like to return some raw files to the camera in order to process them into “watercolor” jpg. However copying them onto the SD card the camera doesn’t find the files. Any tips?
11 REPLIES 11
kvbarkley
VIP
VIP
Where did you put them? They need to be in the DCIM->100Canon folder:
If you have a more complicated folder structure, you may need to go dowh a level.
ebiggs1
"Any tips?"
The camera has an SD, or CF doesn't matter, memory card, you simply need to place the memory card into the card reader on your PC. All you then need to do is copy the pictures you want to transfer to your camera and then paste them into the SD memory card.
EOS 1DX and many lenses.
Thank you both for your kind replies.  I have tried returning the files to the correct folder but I just get the  "No files" message.  I used a freshly formatted SD card, then updated the firmware and still no good.  I am a bit stuck!
If you have edited the raw files in any way then it is possible that the camera will no longer recognise them.
"If you have edited the raw files ..."
I doubt that is a cause.  No editor I know of alters the actual Raw file. The problem is, it is unlikely any editor would understand the edits if they were place inside the Raw file. And certainly no other image viewer would either.  However, I admit I don't use them all.
_________________________________________________________________________________________________
It certainly doesn't work if you make any alterations to the original file name.
Does DPP have the effect your trying to achieve?
I just tried it on my 1D Mk IV.  All jpg worked without problem. No cr2 file did.
I am going to try some more stuff to see why or if.
Thanks for all the thoughts.  Unfortunately it doesn't work with either raw (unedited) or jpg.
