03-11-2024 04:25 PM
I have a Rebel t6i. I got it used about 4 months ago. This weekend, when preparing for a trip, it all of a sudden started not working...
I turn my camera on, and I can see through the viewfinder. The LCD displays the settings for the current mode, and I can change shooting modes. I press the shutter button, and I can take photos just fine, and they will display on the LCD. The problem happens when I push the "Live View" button. The LCD goes black; I can still see through the viewfinder, but pushing the shutter button doesn't take a photo. I hit the "Live View" button again, and the LCD switches back to displaying settings, but the camera is still frozen and won't take pictures. To reset, I have to turn the camera off, eject the battery, wait minimum 3 seconds, and then put the battery back in and turn the camera back on. I leave in 4 days, and don't have time to send it in for repair...
(Yes, I also sent an email to Canon support, but figured I could ask here too.)
03-11-2024 04:58 PM
If you can see through the viewfinder when selecting Live View it means the mirror hasn't moved up. Since you are going away shortly just use the camera as a normal DSLR. Don’t use Live View.
03-11-2024 04:58 PM
03-12-2024 11:14 AM
Thank you for explaining simply what the problem is!
I have figured out how to disable Live View, and will use the camera as a straight DSLR.
03-12-2024 11:19 AM
I recommend you give the camera a good "workover" using the normal viewfinder shooting mode to be sure that the problem is limited to the Live View switch and not a problem with the mirror assembly itself, just to be sure. If this is a very important trip you might want to consider a rental/borrow of a similar camera.
