04-05-2017 08:45 PM
04-05-2017 10:48 PM
Hi Jessicamendenha,
Thank you for posting.
First, please ensure that the battery compartment cover is fully closed.
Next, after you slide the power switch into the "On" postion, what happens if you press the "Playback" button (this has the blue playback arrow on it)?
04-07-2017 10:06 AM
Jessica,
The T5 will power up, turn on, whether it has an SD card in it or not. So, that is not the cause. If you tried two different batteries and it still doesn't work, I think we can also eliminate the battery.
Where did you buy it and when? If it is a reputable store, I would return it for a replacement. It isn't rocket science on how to turn on a Rebel T5. I am sure you have done what is needed. Return it and if you can't, it should have a Canon USA warranty. Call Canon, talk to them and set up a repair request.
04-11-2017 08:33 PM
I had this isssue where the T5i would turn on but then would go off by itself. It seemed like when I removed the battery and put it back in (I have an addon battery grip) it seemed to fix it . But it did it constantly. BUT, I also had a EZ Share Wifi card in it that once I removed it and started using a normal SD Card it hasn't done it sonce. I retried the EZ Share card and sure enough it did it again. Not sure if you have this tyoe of setup but that worked for me. No problem since dropping using a WiFi card.
04-12-2017 09:32 AM
"(I have an addon battery grip)"
If it is a off-brand grip, remove it also. They are only trouble.
06-13-2017 07:54 PM
My t5 does not turn on. I thought the problem was the battery so I replace it, but it still doesn't turn on. I've also switch memory cards as some suggested, and check that it is correctly closed. It still doesn't turn on. Help please!
