09-19-2015 10:19 PM
We have had the SL1 since christmas, and its worked great, up u til this last week, when we realized none of our pictures we took were on the camera. The card is not full; its actually almost empty. The battery is charged.
09-20-2015 08:31 AM
@Pbjsandwiches wrote:We have had the SL1 since christmas, and its worked great, up u til this last week, when we realized none of our pictures we took were on the camera. The card is not full; its actually almost empty. The battery is charged.
SD cards have a small switch that allows them to be write-protected. Make sure it hasn't been left in the wrong position.
Of course if that turns out to be the problem, one wonders why the camera hasn't been telling you that it can't save the pictures. But I guess that's a "B" or "C" issue at the moment. The "A" issue is why they aren't getting saved.
09-20-2015 09:04 AM
Oh, i was all excited that this was the fix, but i moved the switch, and that put it in the locked positn and would not take pictures. 😞
09-20-2015 09:06 AM
I also tried another card with the same problem continuing.
09-20-2015 11:21 AM
Try resetting to default settings. Press the Menu button and then scan through the tabs until you find it. Always a chance that you have somehow accidentally put something on a weird setting accidentally, and if so this could correct it.
09-20-2015 09:29 PM
I think that worked!
09-20-2015 10:43 PM
Great! Much better than a broken camera.
09-21-2015 08:53 AM
Thank you so much!
