05-21-2024
02:57 AM
09:01 AM
I've been having consistent autofocus issues trying to use my R7 with the Tamron 18-400mm lens using the control ring EF-EOS to R mount adapter. The lens will often work fine for the first 5-10 minutes of a photo shoot, but then it will start hunting for focus and be unable to focus on anything. Turning the power off and back on doesn't help. The firmware on both the camera and lens have been updated to the latest versions. I shipped the lens to Tamron for troubleshooting and repair, and they adjusted the autofocus, but that hasn't resolved the problem. The lens works fine on my older Rebel T4i that has the same EF-S mount as the Tamron lens so no adapter is needed. Is it possible that the mount adapter is defective? Or does the R7 with the mount adapter just not work properly with the Tamron lens? According to Tamron, the R7 is supported with this lens.
11-15-2024 10:00 AM
I think that makes sense, I may just buy the RF 100-400 if switching out the adapter doesn't help. I used the Tamron for 4 years so it's not a total loss.
11-15-2024 02:05 PM
Just wanted to update everyone. I exchanged the adapter that had the extra ring on it for a plain one AND walked into the Tamron USA headquarters (lucky me, it happens to be 10 mins away, who knew!?), they updated the firmware on the lens. Played around for about 30 mins and so far its great, no AF hunting!
11-15-2024 03:22 PM - edited 11-15-2024 03:59 PM
Perfect, and now that lens that you've had for the last four years......is still going to be serving you well!
Firmware update resolved the challenge, glad it worked out. Now we know the Tamron 18-400mm Lens can/will work on the R7
If you don't mind mark a post as resolved so that when people search they can easily find the fix.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
11-15-2024 03:30 PM
Wonderful news. Thanks for letting us know.
