07-10-2022 08:32 AM
Team,
Need your help and advise in figuring out the overheating issue with my R6 FW 1.5.2. I set it up at 4K 25.00P light IPB and do not use Canon log and AF mode. Primarily use my camera indoors to make 60-90secs videos.
When I select 4K 25P Light (ipb), I see the total record time as 2:15:47. when I go to shooting mode screen, The shooting time display is 20:00 or 25:00 or 29:59. This keeps reducing drastically as I start shooting.
I shoot approx 25-30 clips of 10secs each before the camera displays the overheating icon and stops recording. This is very disappointed as I was informed I can record upto 30mins of 4k videos. I use CS Express 64gb memory card. I also cleared all settings. No luck.
07-10-2022 09:45 AM
Do you switch the camera out of video mode between takes?
07-10-2022 06:06 PM
Greetings Dsouza,
I'm sorry to hear that your EOS R6 camera is overheating. While the camera is powered on and in use, it will generate heat due to use of the sensor and processor. The camera's overheat protection may prevent the user from recording video if the camera senses the temperature may be too high to operate in this mode.
The environmental operating temperature for the camera would be between 32 degrees Fahrenheit and 104 degrees Fahrenheit. Please note that the camera body may absorb more heat and have trouble dissipating heat if used in hot environments. For example, if the camera is placed under studio lights that produce heat or if the camera is placed near other devices that produce heat. We would suggest to remove any sort of enclosure or case that the camera may be wrapped in while in use to determine if that may be causing for the camera to retain heat.
If the issue persists then we would suggest to send your EOS R6 camera to our facility for service.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
07-11-2022 04:44 AM
Thanks for your response Waddizzle.
I use the LCD as live view/monitor and its ON between the shots. I hit the record button on LCD screen and then hit stop once I'm done. My prep time between shots is approx 1-2mins. I do cooking videos.
I have the power saving display off set for 1min. Pressing the shutter button brings the live view back on LCD. My room temperature is at 25-26c. I do not use artificial lights.
07-11-2022 06:38 AM
I guess that mean that it stays in video mode the entire time. TRy switching the camera out of video mode between takes.
07-24-2022 11:53 AM
It does remain on video mode as I hardly take a min to prep between the shots. I also have the viewfinder, display and auto-off timer to 1min. So if my next shot is delayed by more than a minute, the display goes off.
Can the heating issue be anything to do with the SSD card? Currently using 64GB Scandisk Extreme pro 300mb/s V90.
Also, the 29.59 time displaying on the LCD assuming it's the remaining time on a 4k doesn't change even if I switch up to FHD 25fps. Any thoughts on this one?
07-24-2022 12:00 PM
Try letting the camera’s image sensor rest between shots. Take it out of video mode, so that the rear screen is no longer displaying an image. Try that.
07-24-2022 12:12 PM
Thanks for the tip. Im gone give this a shot. mind sharing your views on the display timing query I have raised? 🙂
