01-18-2024 09:18 PM
Canon R6 Mark ii sitting on my desk, has been turned off for at least an hour.
The access lamp will periodically flash/flicker, and camera makes a brief noise similar to focus noise. IT will do this periodically for a bit then stop. Then a bit later will do it some more.
Battery is in, one card is in. Nothing touching the camera, and camera is OFF.
Any Thoughts?
01-18-2024 09:20 PM
Given the camera is supposed to be turned off, it sounds like a call to Canon Tech Support 800-OK-CANON
01-18-2024 11:41 PM
Are you doing anything in Camera Connect? You can access files even if camera is off.
01-19-2024 12:56 AM
Remove any lens, mount adapter, or battery grip. It might be a good idea to disable wireless communications.
01-19-2024 01:00 AM
Almost forgot. Only use full sized UHS II cards. Format them in the camera prior to first use
01-19-2024 07:44 AM
CinBrandon,
I have r3ad of people having this kind of problem when they still have their Bluetooth connection enabled. You have to cancel the pairing, or put your camera in Airplane mode.
Others traced the problem to IBIS still running.
Others have traced the problem to the GPS location function still running.
Others have traced the problem to a third party adapter.
Steve Thomas
01-21-2024 02:53 PM
Update:
The camera was apparently being "pinged" by some "find bluetooth devices" app my son was using around the house. R6 was doing it too. Silly me thought "OFF" meant OFF.
I guess maybe this is handy feature if you want to access the camera with the app, even when turned off?
I now have "Airplane mode" on one of my custom Menus. Thank you.
