‎01-23-2023 03:49 PM
After switching out of video mode, camera becomes unable to power on. Power must be removed and re-established to use camera again. I have tried two different usb-c dummy batteries, both brand new. Both supply the camera with the specified voltage and amps.
Equipment:
R5c
Dummy battery
PD USB-C power bank 100w
Steps to reproduce:
1. Connect camera, dummy battery and power bank
2. Switch camera into Video mode
3. Switch camera to Photo mode
I have tried turning off sensor cleaning at shutdown, it has no effect
‎01-30-2023 03:49 PM
Hi Rick,
Apologies for the late reply, we've been dealing with some serious flooding over here in Auckland NZ.
I think you're right, the amps is likely very relevant to this situation. The second dummy battery has an output of "2~3A". I have done some testing with the LP-E6N and LP-E6NH batteries, and found some surprising results.
Firstly, some output calculations from these batteries (please correct me if I am wrong, I'm no electronics expert) - Both Canon branded batteries.
LP-E6N: 7.2V, 14Wh = 2.0A
LP-E6NH: 7.2V, 16Wh = 2.2A
So the LP-E6NH doesn't even reach 3.0A, and works perfectly fine.
And whats really interesting is the LP-E6N causes the exact some issue (camera locks up when turned off from Video mode).
So if you have an LP-E6N lying around Rick, I would be very interested to see if your R5c exhibits the same behaviour.
‎01-30-2023 05:01 PM - edited ‎01-30-2023 05:09 PM
LP-E6N... I do. Have at least 3 for my 6D2. I know they work in the R5. I thought they "could" work in the R5 C as well. I don't remember for sure, and have never tried. I think there is a charging limitation - cannot be charged (in the camera or grip?). I just don't remember which. At work, will try this evening.
‎02-10-2023 01:31 PM
Hi Rick, any updates on the test?
