05-18-2025 08:33 AM
05-18-2025 08:35 AM
Since doing a software upgrade I can't reduce my shutter speed below 5", I used to be able to do 30" in manual/AV/TV modes - but not now. I have checked the minimum shutter speed and the one under ISO and they are correct.
05-18-2025 10:42 AM
"R5 V-1" shutter speed ?🤔
Sorry not following. Are you using mechanical or electronic shutter?
05-18-2025 11:43 AM
I have firmware 2.1.0. I can set 30" in manual mode. Under Camera Tab 2, 4th item is Set shutter speed range. I assume that is the one that you are referring to but thought I'd point it out just in case.
Maybe remove the battery to get a good reset?
05-18-2025 12:41 PM
There are limitations for the shutter speed when using electronic shutter mode.
https://cam.start.canon/en/C003/manual/html/UG-03_Shooting-1_0240.html
The manual mentions this in the caution note.
Precautions when set to [Electronic]
Some restrictions on shutter speed apply. Shutter speeds slower than 0.5 sec. are not available.
05-18-2025 12:59 PM - edited 05-18-2025 01:01 PM
I bet that's the issue. I just tested with my R5 using the 35mm f/1.8 and it does not go below 5" when using the electronic shutter.
