09-05-2024 04:09 PM
On my screen in Photo mode, I have an icon which does not seem to be in the manual. It is in two parts. A white half filled circle with a 0.0 beside it. It is just above the focal length and to the left of where the GPS indicator comes up. See attached. I have on the RF 100mm macro lens if that helps any.
09-05-2024 04:16 PM
It appears to be connected with the SA adjustment of this lens. The half filled white circle doesn't change but when the SA is adjusted the numbers can range from +2 to -2.
09-06-2024 06:10 AM
Does the symbol only appear when you have the RF 100mm F2.8L Macro IS lens on the camera, and disappears for all other lenses? If so then your idea about it being the SA value makes most sense.
If you don't want it then you can remove it from the display by using the shooting information display setting menu and navigating to lens info where you will find SA.
https://cam.start.canon/en/C017/manual/html/UG-03_Shooting-1_0430.html
09-05-2024 11:05 PM - edited 09-05-2024 11:07 PM
I am pretty sure that this symbol refers to the picture style (specifically contrast) that you are using, as per the advanced user guide, P213: From the menu RED chapter, P4.
If you press INFO you can see the symbols displayed in more detail.Picture Style details with INFO button
If you press INFO you can see the symbols displayed in more detail and this symbol is assigned to contrast. The shading is possibly reversed on your display because it is a white background.
09-06-2024 08:20 AM
I'll Mount my RF 100 tomorrow and see if I get the same icon for SA adjustment.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
