06-21-2021 11:16 PM
03-25-2022 04:43 PM
Have you upgraded to all latest firmware? I just installed 1.5 on my R6 and it is now AWESOME!
03-25-2022 11:06 PM
Yes I have firmware 1.5.2 installed. There is still the 3 to 5 second "floating" or searching before full stabilization on my R5. Are you saying that you used to have this experience on the R6 but now it is gone after the firmware update?
01-30-2025 09:41 PM
Did you ever find a resolution? I have this issue on my R7 and EF 100-400 MKII.
01-30-2025 10:27 PM
Unfortunately no. I think it's just normal operation for Canon. It's pretty annoying with fast, brief subjects like small birds that are gone 3 seconds after showing up, but I've gotten used to it. Or at least, I accept it I guess. I still get great photos, but much fewer keepers in the first 4 seconds
01-31-2025 07:07 PM
I have read that IBIS is not used with EF lenses that have built-in IS.
01-31-2025 07:55 PM - edited 02-01-2025 08:16 AM
I suspect you are 100% correct. I went to National Camera Exchange this afternoon and tested their copy of the RF 100-500. It had the same delay of 3 seconds that my EF 100-400 MKii has. Seeing how one is RF and one is an adapted EF lens, I was able to rule out the lens as the cause of the issue.
I then tried their copy of the Canon R7 against mine. I used all my normal settings that I use for wildlife photography, and theirs I factory reset. The only changes I made to theirs was enabling tracking and Servo AF. Both bodies had different firmwares, my copy is up to date, while their display model is 4 versions out of date. I used my copy of the EF 100-400 MKii on both bodies.
Both bodies had the same delay of 3 seconds. This seems to indicate that it is just how Canon bodies handle the IS.
02-01-2025 05:24 AM
Sorry but that it not true. EF lenses with IS do work in tandem with the IBIS in the cameras.
However there is a greater integration of the two systems with selected RF lenses.
https://cam.start.canon/en/H001/supplement_0050.html
02-01-2025 08:11 AM - edited 02-01-2025 08:15 AM
I don’t know where you supposedly read that, but it’s factually incorrect and you should stop spreading misinformation.
Secondly, and more importantly, what does that have to do with the topic being discussed?
If you don’t have anything useful to contribute, why post? Honestly, it’s wildly annoying when people go looking for an answer to a problem, such as this, and end up having to sift through nonsense replies that are factually incorrect and not even remotely related to the problem.
You’ve been on here since 2012, you should know better.
02-01-2025 11:10 AM
Greetings.
I am curious to know how you are reaching your conclusion about IBIS being delayed for a few seconds.
What are you expecting to happen that doesn’t happen almost immediately?
I did not reply previously because you did make any mention of shooting conditions or camera settings. You only named the gear.
IBIS is a crucial part of the AF system. Image Stabilization’s main function is to present a stable image to the AF system and the viewfinder. Without it, the camera would probably never be able to identify and track eyes, for example.
