02-15-2025
01:05 AM
09:45 AM
Arthur
Let me try and explain.
EOS RP set to Movie. USBC to my PC. Using OBS, there is a slight sync issue where the video is behind the audio. Any suggestion to add a delay or something to the audio?
thx!
02-16-2025 12:34 PM
If you are taking video from the EOS RP using USB-C, what software is then providing the video feed to OBS? Are you using the Canon EOS Webcam Utility?
How are you putting the audio in to OBS, is that with a mic connected directly to the computer, or with a mic plugged in to the EOS RP?
I know that when the camera sends video and audio in the same HDMI cable that the two will be in sync, but when I feed HDMI from a camera, and audio separately in to a Blackmagic ATEM Mini Pro there is a lag between video and audio. Fortunately the AtEM Mini allows me to set an offset in frames to overcome this.
02-16-2025 01:05 PM
Camera source into OBS only for video
Audio is coming through a USB connected MIC for the stream.
When I watch the live feed in OBS, the delay in video to what I'm actually doing is visible.
02-17-2025 02:43 AM
You may need to add a delay to the audio input to match the video.
08-20-2025 01:34 AM
Hey guys!
EOS RP user here. Using MeldStudio as my broadcasting software. Any way to get my camera to output at 60fps at all? I have it set to HDR so I can do the clean HDMI output in the camera settings.
Also, there is audio/video sync issues still. Camera is USBC to PC while using a USB mic to PC.
thanks!
