03-20-2025 05:15 PM
03-20-2025 05:42 PM
Is the camera set to continuous high if not it will only take 1 picture. Single Shot will also do that too.
03-20-2025 06:10 PM
It’s on electric, will only take one image where yesterday it was continuous
03-20-2025 06:20 PM
Are you sure its still set to continuous high and it hasn't been changed. Also what lens are you using please post the FULL NAME of the lens you're using. A complete would be RF 70-200mm F/2.8L IS USM Z not "RF 70-200mm L". Example lenses are posted below to help you identify your lens.
03-20-2025 06:27 PM
Electric shutter mode is continuous mode on the R5, it just stopped working. No settings were changes, I’m using the RF 100-500 with it.
03-20-2025 06:34 PM
Continuous what Low High or H+. There can be setting that's preventing that such as focus bracketing. I would save your settings to the SD Card then do a factory reset. Then reset the custom functions back to factory default.
03-20-2025 09:24 PM
fan4jg24,
How does your mechanical shutter behave? Has it stopped shooting bursts as well?
Steve Thomas
03-20-2025 09:43 PM
@fan4jg24 wrote:
"Electric shutter mode is continuous mode on the R5"
That is incorrect. Elec. shutter is just one of the three different types of shutter you can select and has nothing to do with continuous shooting. You have to be in one of the continuous shooting modes regardless of the shutter mode.
Please double check that you are not in "One shot".
Newton
03-21-2025 08:26 AM
It only takes one on that mode as well, had wondered if I killed the drive. I’ve had the camera for 3 years and shoot everyday
03-21-2025 10:16 AM
fan4jg24,
Ah. So in both electric and mechanical shutter modes, your camera won't take a burst of shots. It sounds like the problem is in the high speed continuous setting. Does low speed continuous work, where it takes like 3 shots per second?
To me, it doesn't sound like your electronic shutter is the issue.
Steve Thomas
