02-19-2023 11:52 AM
Anyone in Rx land is eperiencing the following error when trying to connect the camera with the EOS Utility launcher software version: EU-Installset-W3.16.0.7
Error message: EOS-xxxxx pairing (connection) with the computer in progress. Start EOS Utility on the computer.
Windows 10
My was working fine until it stopped. I then upgraded from EOS Utility 3.15.20 for Windows to W3.16.0.7 However same issue where it gets stuck at EOS Pairing (connection) with the computer in progress. Start EOS Utility on the computer.
The utility was started on the computer but it does not find the R3 Camera.
I know the camera was assigned an IP and I can ping it but the software fails to connect. I tried on another computer and experience the same issue.
On my other computer I did say allow Canon to make changes to firewall and I check and everthing pretty much said "Allow" for "Canon EOS UPNP Detector"
02-20-2023 01:25 PM
I ended up going to "add remove programs" and removed every reference of canon software, rebooted and reinstalled the drivers "W3.16.0.7 " drivers. That did the trick.
02-20-2023 01:25 PM
