10-07-2015 07:18 PM
I have not used my camera in months, now after months my pictures are purple when I take them. Any ideas?
10-07-2015 08:15 PM
Can you post a sample?
it could be someone set a weird custom white balance, or you accidentally did. Try resetting all settings to default in the menu.
Does it it do purple in all lighting conditions? Sun? Fluorescent? Shade?
Does it it happen in all white balance settings?
10-07-2015 08:22 PM
10-07-2015 08:25 PM
But BOTH cards do this?
10-07-2015 08:27 PM
To rule out the problem being the card, try both cards. If it is just one of them the card is the problem. Reformat the bad one (in the camera) and see if that is the problem.
10-07-2015 08:28 PM
10-17-2015 11:34 AM - edited 10-17-2015 10:39 PM
@jess024321 wrote:
Just checked the other cars. Both of them do this.
It's been more than a week, and nobody seems to have said this yet, so I will. If reformatting the cards and resetting the camera to factory settings haven't cured the problem, it probably needs repair. That's assuming it's new enough, and expensive enough, to be worth repairing; I don't believe you told us what model it is.
I would surmise that a purple image could indicate a failure to record the green channel. If so, and if it's not just a loose wire, you're probably looking at a board replacement.
10-17-2015 01:47 PM
