12-31-2019 05:18 PM
I'm seeing a couple of horizontal blue lines on the screen of my Rebel T3. It's not an issue with the card, which is fine on another camea. They are irregular, and not gridlines. Is this a sensor issue? Is it worth fixing? Thank you!
01-01-2020 02:05 PM
You've got it-- the pictures viewed on the computer do NOT have the lines, just when viewed on the camera (I don't use this camera much anymore, so I had to reacquaint myself with it!). Yes, it's annoying but good to know that photos are unaffected. Thank you.
12-31-2019 06:25 PM
It looks like a sensor issue. Take a few photos and see if it shows up in the photos.
12-31-2019 07:47 PM
Thanks, Indeed it does show up in the photos. I'm going to assume that the fix would be more expensive than a new/used camera body?
01-01-2020 09:31 AM
For a T3, yes.
You can get a refurbished Rebel T7 from the Canon eStore for $340.
01-01-2020 09:54 AM
@dpotort wrote:Thanks, Indeed it does show up in the photos. I'm going to assume that the fix would be more expensive than a new/used camera body?
Did you look at the photos on a computer, or in the camera? Do you see those lines when you browse the camera menus?
01-01-2020 10:33 AM
"Did you look at the photos on a computer, or in the camera?"
This is important. It could be your LCD which is annoying but not harmful to the actual photo.
01-01-2020 11:45 AM
@ebiggs1 wrote:"Did you look at the photos on a computer, or in the camera?"
It is very important. If you are viewing photos in the camera, try to zoom in to see if that makes a difference. I think you may actually have a LCD issue.
01-01-2020 02:05 PM
