02-25-2021 08:35 AM - edited 02-25-2021 08:38 AM
I’m using a remote trigger via the shutter release port. After image capture, the LCD screen only shows the horizon level indicator, but no preview of the taken image. The only way I can see the image I’ve taken is to unplug the cable to the remote trigger. How can I see the image preview without having to do this after every capture? I'm using an EOS 5D MkIV.
02-25-2021 10:41 AM
Flash out is to trigger a flash, not the camera.
You need a remote shutter trigger, not a flash trigger. I hope you have not damaged your camera.
02-25-2021 10:56 AM
You won't know whether anything is damaged until you plug in a real remote shutter release.
02-25-2021 09:16 AM - edited 02-25-2021 09:18 AM
Just tried this with my 5D IV with the RS-80N3 and couldn't reproduce the issue.
Capuring an image via the remote always put up the capture briefely on the LCD screen. I then pressed INFO until the level was displayed. Took an image via the remote and it briefly showed on the LCD. Then the level showed again. Pressed INFO one more time to return to the Quick settings display. Third image captured, showed briefly on the LCD screen.
Having said all that, I was in Manual mode, and shutter set to 1/200 (i.e. something other than Bulb).
02-25-2021 09:43 AM - edited 02-25-2021 10:07 AM
As soon as I attach the remote cable to the receiver, the LCD screen shows the level indicator, and all buttons on the left are disabled.
Im not using the RS-80N3 cable release. I'm using a Vello Freewave wireless trigger.
02-25-2021 10:07 AM - edited 02-25-2021 10:08 AM
Which remote trigger?
ETA:
Posts crossed in the Ether.
Do you have a model number?
02-25-2021 10:11 AM
Vello Freewave Flash Trigger LR (RFWLR)
02-25-2021 10:33 AM
I seee nothing in the manual about using this to trigger the shutter. It looks to me that the 3.5mm port on the Vello is labeled "flash out", which is not what you want at all.
02-25-2021 10:39 AM
Can you clarify what 'flash out' means and why this isn't what I need? What do I need? :O)
02-25-2021 10:41 AM
02-25-2021 10:44 AM
Camera is fine fortunately. Thaks for your help.
02-25-2021 10:56 AM
