Over exposure
greyeagl53
I have a Canon Rebel T5 and use a Precision DSLR300 Auto Flash.  When shooting on automatic and with the flash pointed straight up I get a very overexposed photo.  This happened in a very large dance hall.  My built in flash works OK with limited range, but no over exposure.  It happens with all my lens.  Any ideas or suggestions are appreciated, Thank You in advance.
Modern automatic flashes use several incompatible technologies for communicating with the camera. Your T5, if it's like most recent Canons, expects the flash to use a technology called E-TTL ("Enhanced Through-the-Lens"). If for example, the flash uses the earlier TTL ("Through-the-Lens") technology, the result is precisely as you describe.
Some flashes can be set either way, so check into that before you give up and buy a new flash.
Bob
4 REPLIES 4
Skirball
I've never heard of that flash, but I'm guessing it's a manual only flash.  So, you put your camera in auto, and it tries to determine what the proper exposure is (without the flash), takes the shot and fires the flash which only adds to the exposure.  How much you over expose depends on the power level you choose.
Using a manual flash with any sort of auto setting on the camera is difficult and takes understanding of what the camera is trying to do and how it's exposing.  Even then, there's going to be a certain amount of guess work and experience.  If you want to do it this way I'd recommend moving your exposure compensation down two stops.  So the camera tries to underexpose the scene by two stops, and then dial up the flash power until the exposure looks decent.  Depending on what the flash hits the exposure is going to vary.  Just keep in mind that the camera will have no idea what the proper exposure is, because it has no idea how much light the flash adds to the scene.  The only way is to check the image afterwards and adjust accordingly.
I do this a fair bit with my camera in manual and an off-camera flash in "dummy mode" shooting straight into the ceiling.  I'm constantly checking my results and adjusting, but I find it to work quite well.  But by getting my flash off camera I can get consistent results from it.  So in essence it just becomes another ambient light.
I'll try that, Thanks
Bob
Thanks Bob
