No Display of Histogram, electronic level, and grid with R6MkII
KenKPhoto
I suddenly lost the histogram, electronic level, and grid in the EVF, while shooting in photo mode.
I reset the display and re-entered, with no result.
I also updated the firmware to the current version 1.5, also with no result.
What can I do next?
Thanks in advance.
p4pictures
While looking through the EVF press the INFO button to cycle around the different display options. By default there are three different displays possible. One of the three has the histogram and electronic level.
Note that the EVF displays are not synched with the LCD displays. So the easiest way to do just the EVF is to fold the LCD screen away so it is not possible to be seen.
Brian
3 REPLIES 3
Try cycling the Info button in playback with the image displaying.
p4pictures
Brian
Thanks to you both.  p4pictures' solution worked!
