02-14-2019 02:32 AM
02-14-2019 10:19 AM
You need to learn about the exposure triangle. Any particular scene has a combination of ISO, shutter and Aperture that produces a good exposure. If you change any one of the three, like shutter time in your case, you must compensate by adjusting the other two to keep the same exposure.
For example, if a shutter speed of 1/60 second and an aperture of f/4 and an ISO of 400 gives you a good exposure, in order to increase the shutter time to 1/30 you must at the same time you must increase the aperture to f/2.8 *or* the ISO to 200 in order to keep that exposure.
02-14-2019 09:25 AM
How long an exposure? You probably need a neutral density filter.
02-14-2019 09:34 AM - edited 02-14-2019 11:15 AM
@Tank wrote:
Hi all,
I’m completely new to photography and need a bit of help. I’m shooting on an EOS 600D. Love the camera, but there’s one thing I can’t figure out and it’s driving me crazy.
What settings do I need to have it set at to take long exposure photos without the photo just being a white screen. I’ve played with aperture and lens timing, but I just can’t seem to get it right.
I know it’s probably a very silly question, and I’m kinda expecting some smarta$$ remarks, which I guess I deserve to a point, but any useful replies or some guidance would be greatly appreciated and I would be very thankful.
Thanks in advance folks. 🙂
What do you mean by "long" in this context, and what lens (and what settings) are you using? One additional way to combat overexposure is to lower the ISO setting. But it would help to know what subjects you're trying to capture and in what lighting conditions.
Long exposures usually aren't necessary in the digital world. Do you mean really long, as in astro-photography? We have at least one astro-photography expert in the forum.
02-14-2019 10:19 AM
02-14-2019 10:55 AM
" I need to have it set at to take long exposure photos without the photo just being a white screen."
A completely white screen is showing and extreme over exposure. A totally black screen on the other hand indicates an extremely under exposed one. Make sense? You need to do whatever is necessary to get the exposure more correct.
What is it exactly you are trying to do? Nobody can tell you how if we do not know a lot more of the details. It is fine to tell you to just read some books about exposure but sometimes it is best to just show you how. More details!
02-14-2019 01:27 PM
02-14-2019 01:37 PM
I should have pointed out that the cameras Tv mode will do exactly this,You can set the shutterspeed and the camera will try to set everything else to get a good exposure.
02-14-2019 01:41 PM
It is amazing what you can learn from the manual:
02-14-2019 02:07 PM
Here is an article for you:
Clipped from: https://digital-photography-school.com/4-tips-for-shooting-drop-dead-gorgeous-waterfalls/
Waterfalls are a very popular subject for landscape photographers. The draw to their natural beauty is clear, but sometimes coming home with the best shots is harder than you might think. As the curator for the Google+ Photography theme, #WaterfallWednesday I get asked how to take better pictures of waterfalls every week. So let me share some tips with you.
This waterfall was very full and the light was low. At 1.6 seconds, I let this exposure go too long leaving the water without details.
On Manual, I usually start with the slowest ISO my camera can go, 100. Then I set my aperture small enough to maximize focus, usually around f/8 to f/10. Then I see what kinds of shutter speeds that nets.
For the big falls, I try to keep my exposure under a second. Anything between ¼ to a full second will show the water’s motion and still retain all the detail in that movement.
Small stringy waterfalls just love putting on a show with longer exposures. These shots look great when you can go as long as possible. Don’t be afraid of the small aperture police who say you will lose sharpness. Photography is always about compromises and in this case, the slightest loss in sharpness only visible when viewed at 200% is greatly outweighed by capturing the water’s movement. Don’t be afraid to use f/22 if you need it. I try to shoot for exposures 1-4 seconds long at these kinds of waterfalls.
You probably will also want a neutral density filter to cut down on the light entering the lens. At a slow shutter speed you may not be able to stop down enough to avoid overexposure.
02-15-2019 12:02 AM - edited 02-15-2019 12:12 AM
There are three variable elements of a camera that you can control - the "Holy Trinity" of exposure, so to speak... The aperture, shutter and ISO. If you want to take long exposures then you first set the ISO to its lowest setting - that makes the sensor very slow to react to light. Now set the aperture to its highest setting that lets in light as the slowest rate, and finally set the shutter speed to the slowest you can manage - setting the camera to Av mode would do that for you. If you want exposues so slow that they are over-exposed you will need to invest in a Neutral Density filter. That is a filter that reduced the amount of light coming into the lens - the degree of such reduction is usually measured in stops, so if you want something really slow you might want to look at an 8 to 1-10 stop filter.
EDIT - I just saw your comment about wanting to shoot water falls. Unless you are in very bright lighting conditions you should be able to get away with low ISO and fairly high f value. I shoot waterfalls at around 0.25 to 0.5 seconds.
this exposure was timed at about 1/3sec.
This is at 1/4sec.
If you want to upgrade your photography skills go to your local library website and look in the catalogue for Lynda.com you may be lucky enough to find a listing for it. In that case you will have free access to one of the best video tutorial websites I know. If you click on the listing you will go to a sign-in page where you input your liibrary ID and passord and you're good to go. There are excellent videos on all aspects of photography from the most basic to very advanced. and you will get a lot of good information from excellent professional teachers. If you don't have free access via your library, you can go to Lynda.com and sign up for a free month's trial access without commitment. It's definitely worth the effort. I would suggest doing a search for Ben Long or Photography Foundations, and you will find a host of courses.
