Need a Lens Adapter for T3i
GalacticDonuts
I use a Canon T3i camera and recently purchased the 28mm Macro Lens only to discover the two are not comparable. Should I return the lens or is there some kind of adapter I can get to match the smaller lens connector to the larger camera?
stevet1
GalaticDonuts,
If you got the 28mm Ef mount lens, you won't need an adapter, but if you got the EF-M lens, then yes, it won't work. To the best of my knowledge, Canon doesn't make an adapter that will let you use M lenses on an EF mount camera.
Steve Thomas
1 REPLY 1
stevet1
GalaticDonuts,
Steve Thomas
