06-01-2024 10:01 PM
I use a Canon T3i camera and recently purchased the 28mm Macro Lens only to discover the two are not comparable. Should I return the lens or is there some kind of adapter I can get to match the smaller lens connector to the larger camera?
06-01-2024 10:33 PM
GalaticDonuts,
If you got the 28mm Ef mount lens, you won't need an adapter, but if you got the EF-M lens, then yes, it won't work. To the best of my knowledge, Canon doesn't make an adapter that will let you use M lenses on an EF mount camera.
Steve Thomas
06-01-2024 10:33 PM
GalaticDonuts,
Steve Thomas
