My EOS R5 has the aperture stuck at the lowest F of my lens and is unable to change to other value
Brokencanonr5
Is this problem common to many R5?
Brokencanonr5
Thank you very much! You save me $490 for the estimated repair cost.
5 REPLIES 5
Greetings
It's not typical.  Might it be an incorrect setting, hardware incompatibility or failure?  Does this happen with any lens or just one?  Take a look at your custom functions.  C.Fn.. There is a setting that allows you to specify a range for selectable apertures.  Resetting your camera settings is another option.
March411
I've only seen one other recent report of this type of problem and it was a problem with a menu setup.
You don't say how your are trying to make adjustments to the aperture that is stuck. Have you looked at the button/dial customization menu to make sure they are set up?
Menu
Camera/Orange menu
Screen 3
Customize dials
If you can't find/resolve the problem I am confident Canon can assist you, go right to the source, save yourself some time and frustration. 800-385-2155 or 800-652-2666
Marc
Windy City
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
p4pictures
Did you change the setting for the aperture range in the custom functions menu, C.Fn2 there is a setting labelled Set aperture range, and if it is changed from the default there will be a blue coloured asterisk on the right. If this is showing then you might want to change this back to the defaults which are Max. aperture 1.0 and min. aperture 91.
Check this page of the manual, you need to scroll down a little to find the Set aperture range section.
https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/My-canon-R5-has-the-aperture-stuck-at...
Brian
Brokencanonr5
Glad to help, can you possibly mark my reply as a solution too?
Thanks,
Brian
