03-28-2024 02:40 PM
Some context it’s currently 72° outside and sunny. I am shooting in a raw and have been operating the camera for less than 30 minutes. I have taken less than 30 photos and the back panel under the screen isn’t even warm to the touch. Is this normal behavior for an r8
03-28-2024 03:58 PM
Are you seeing an overheat indicator?
Are you using a OEM battery and is your memory card full size or micro SD with an adapter?
03-28-2024 05:08 PM
Yes I’m seeing the overheating indicator. Also yes it is an OEM battery and it’s shooting to a full size SD card from Sandisk
03-28-2024 05:38 PM
Coozlw,
Does the same thing happen when you shoot jpgs, or just when you shoot RAW?
Steve Thomas
03-28-2024 05:40 PM
I’m not sure, I shoot exclusively in raw as I deal with nature photography.
03-28-2024 06:01 PM
Coozlw,
Just for the purpose of this experiment, try shooting 30 jpgs and see what happens.
Steve Thomas
03-30-2024 02:18 PM
I have tried this and received no over heating.
03-30-2024 03:56 PM
Coozlw,
The reason I asked is because with RAW files being so much larger, I wondered if your camera was having a problem with processing that many large files at a time.
You could try switching to C-RAW and see if it makes a difference.
Steve Thomas
03-31-2024 09:50 AM
@Coozlw wrote:Some context it’s currently 72° outside and sunny. I am shooting in a raw and have been operating the camera for less than 30 minutes. I have taken less than 30 photos and the back panel under the screen isn’t even warm to the touch. Is this normal behavior for an r8
Welcome to the forum! Sorry to hear you are having issues with your gear. Your issue is unusual. A little more information about your shooting conditions and simple test would be beneficial.
First, what color is the overheating indication when it appears? It can normally appear on the display. It is normally WHITE. It turns RED when there is an issue.
What brand and model lens are you using? If your lens requires a mount adapter, what brand of mount adapter are you using?
You say that you captured less than 30 photos before it showed signs of overheating. Were these long exposures? Do you use the EVF or the rear screen to capture shots?
03-31-2024 10:14 AM
Hello!
I'm not a tech, but I've been doing this for a very, very, very long time.
It's very rare for the camera to have temperature issues during normal photography sessions. HERE is an excerpt from the manual:
