09-21-2019 09:46 AM
09-22-2019 01:47 AM
Hey Charlie,
This might be the touch screen setting in the bottom left corner of your screen, I noticed that I sometimes turn mine off by accident too. In the bottom left corner you should see a small icon that looks like the back of your camera and it might say "OFF" over it. touch this part of the screen and the touch functions should change. There's also a section in the manual (linked below) that explains some of the mroe advanced touch operations as well in case you're interested in customizing the camera a little more to your liking.
http://gdlp01.c-wss.com/gds/3/0300029803/01/eosm50-um-en.pdf
Hope this helps, have a great weekend!
09-22-2019 07:03 AM
09-22-2019 08:30 AM
Hi Charlie1173,
Thanks for you response.
Does the screen become unresponsive after you've fired several shots? In that case, the camera's buffer might have filled up. During that time, the camera might become temporarily unresponsive as the images transfer from the buffer to the memory card.
If the touch screen remains unresponsive even when you haven't fired several shots at a time, then you may wish to consider your service options.
The service options will vary depending on your location and are subject to change, so I would suggest that you email to get the latest repair details for your area:
eosdigitalsupport@cits.canon.com
09-22-2019 08:39 AM
09-22-2019 08:40 AM
09-22-2019 09:46 AM
The sensor that blanks the screen is located by the rubber piece that is on the viewfinder. Make sure the rubber piece is fully and properly seated. It slides off in an upward direction. Push down on the top of it to make sure it is in its’ proper place.
09-22-2019 12:08 PM
