06-03-2020 12:53 PM
Hi All,
Can anyone here make recommendations on how and what kind of wifi adapter I can buy for my Canon 5Ds?
I've looked at the Canon website and this is what they have Canon W-E1 Wi-Fi adapter. I don't particularly like this solution because it would take up the SD slot.
Curious anyone used this and could give me feedback?
Thank you.
06-04-2020 10:28 AM
@Mark35mmF2 wrote:Hey there,
Yes, it sounds like the W-E1 won't be a good fit for you, it is not very fast so it would only really be of benefit for transferring small sets of images or just individual images at a time and as a few of you have stated, those large 50 megapixel files certainly won't make it faster. The WFT-E7A would be the best option but it also sounds overspecced if all you want to do is transfer your images from inside the camera, its primarily used for active uploads to a server during news gathering/live events and live tethering over a wide area.
From the sounds of it you may be best off just using a card reader with a thunderbolt port for your Mac, or a USB card reader with USB adapter on the Mac.
I concur with Mark's points. The main reason for having WiFi isn't to avoid buying a card reader; it's so that you car quickly send your pictures to a newspaper or Web site under deadline. But under that circumstance, you're hardly going to be using a 5Ds, because you don't need, or even want, all that resolution.
06-03-2020 01:54 PM
@limvo05 wrote:Hi All,
Thank you.
Where did you get the piece of information? From the User Manual? WFT-E7A Wireless File Transmitter is another option.
06-03-2020 03:56 PM
This is where i found it https://shop.usa.canon.com/shop/en/catalog/wifi-adapter-w-e1
06-03-2020 04:30 PM
@limvo05 wrote:This is where i found it https://shop.usa.canon.com/shop/en/catalog/wifi-adapter-w-e1
I apologize, but your link does not indicate why you selected it.
Scroll down to the "wireless" section.
06-03-2020 04:40 PM
I was just looking to see if Canon has a wifi solution, and that's what came up in my search. I never heard of this product till now. No specific reason.
06-03-2020 05:01 PM
I guess this borders on being off-topic, and it's personal opinion anyway. But the times I'd want to use a 5Ds, and the times I'd think it necessary to use WiFi, would hardly ever intersect.
06-03-2020 05:30 PM
Valid point! The files generated by the 5Ds are rather large, thus, I really wanted to know how long it would take to transfer the files via wifi? If it is not fast, then it might defeat the purpose.
Thanks.
06-03-2020 06:44 PM - edited 06-03-2020 06:49 PM
@limvo05 wrote:Valid point! The files generated by the 5Ds are rather large, thus, I really wanted to know how long it would take to transfer the files via wifi? If it is not fast, then it might defeat the purpose.
Thanks.
Curious to know why this ended up under the heading of LENSES?
Personally I find it easier to remove a card and pop it in a reader that is then recognized as a drive by my computer. To me the disadvantage of using WiFi or cables to download directly from the camera is that I chew through battery capacity for (what I percieve as) no particularl benefit.
06-03-2020 07:05 PM
Trevor, I agreed with you on this. That said, with the newer Mac, it does not have a built-in SD card reader, so I would have to plug the card into an external card reader, then connect the card reader to the mac.
Again, I was just curious how everyone is doing it, and what options available.
Thanks.
06-03-2020 07:38 PM
