05-30-2016 01:20 PM
The LCD on my Canon T5i goes black when HDMI or mini USB is plugged in. Thoughts?
05-30-2016 05:49 PM
Tell me more
05-30-2016 05:53 PM
05-31-2016 09:39 AM
You have to use the wiredly shaped AVout cable that connects to the USB port.
The one for my T6S - which is prbably the same is the AVC-DC400ST
http://shop.usa.canon.com/shop/en/catalog/stereo-av-cable-avc-dc400-st?searchTerm=avc-dc400ST
05-31-2016 10:42 AM
Just talked with Canon. Keeping the LCD on while attached to the HDMI is called screen mirroring. This feature is permitted only on the higher-priced cameras 😞
Also, headphone monitoring is not available except on the higher-priced cameras and camcorders because you can't sell more expensive cameras if you offer even pretty basic features like these on the T5i/Rebel series.
Magic Lantern doesn't solve this problem either as no audio menu appears on the build for the T5i.
So - boo Canon for dumbing down the T5i but I'm ok with ML for uncovering what features it can. Please add the audio menu to the T5i (particularly the headphone monitoring option) in the next build.
05-31-2016 12:58 PM
"Keeping the LCD on while attached to the HDMI is called screen mirroring. .... Also, headphone monitoring is not available except on the higher-priced cameras and camcorders because you can't sell more expensive cameras if you offer even pretty basic features like these on the T5i/Rebel series."
Adding those features probably requires doubling up, and duplicating the HDMI signal circuitry, which would significantly raise the cost to build it. Ditto, for the audio. Not everyone will be using the cameras in that fashion.
If you want the more advanced feature, then you have to pay for it. The Rebel series of cameras are entry level performers. They are mostly targeted at people who are upgrading from a camera phone, or a point and shoot.
