LCD Monitor is Black
solmaz
I have a EOS 250D camera. The LCD monitor is totaly black but all other functions are working. It happened before but LCD monitor started working and now LCD monitor is black again. Would you help me please if you can. Many thanks.
6 REPLIES 6
Tronhard
VIP
VIP
Can you please turn on your camera, and press the INFO button repeatedly - waiting a few moments between presses?  It is possible that the button has been pressed and has gone into black mode.
cheers, TREVOR
solmaz
Thanks, but it did not work and LCD monitor/display is black What else can I try
You probably need to contact Canon and see about service.
Tronhard
VIP
VIP
Likely John is right, but before you do. Have you browsed through the manual and reviews all references to the LCD display and how it is used?  In particular, I am looking at P272, but there are other references that might help you.  I suggest downloading the PDF version HERE of the manual and doing a search for LCD.
cheers, TREVOR
Yes, I did go through the taxes related to LCD, but some of them refer to LCD display, no use..
I really think I press a button or two accidentally, but I could not find which one.. the guide did not really help. There is no info about if LCD becomes black, which button turns LCD black.
Tronhard
VIP
VIP
OK, then looking at the VF, or by following the manual blind, follow the instructions in the manual to do a factory reset of the camera.  That should reset anything you have inadvertently set.
cheers, TREVOR
Friends and Family
