04-19-2020 04:02 PM
Hi all,
I just purchased a starter camera. (Canon T7) It has two lenses that came with. The 18mm-55mm which has IS, and a 70mm-300 that does not. I like to take senic landscape photos, nature, and just about anything that catches my eye. What would be the next logical lens for me to buy as an upgrade? I was looking at two lenses. One is the 18mm-135mm the other is the 70mm-300m with IS. Do you think they are decent choices? Is there another lens I should look at? Keep in mind I am on a budget of about $500. Thanks so much for reading.
Earl
04-22-2020 07:27 PM
04-22-2020 07:29 PM
@snapshots wrote:
I am not familiar with the model numbers for canon lenses but I will get familiar. Thanks for sharing the link to the videos. I will watch them.
Check out the two video series at the ink i provided.
04-23-2020 11:26 AM
04-23-2020 11:32 AM
I find myself using the apeture priority mode the most so far. I really bought the camera for a work trip I took to Alaska back in Feburary. Mostly pictures of the sencery. Maybe I can post some to what you'll think?
04-23-2020 11:42 AM - edited 04-23-2020 11:43 AM
I am sure everybody here has different opinons about how to go about learning this stuff. I came here because I'm sure you folks can offer some great information and advice. I appreciate it all. Also, I don't see a link to post photos in the share your photo section? Maybe I'm too new to be able to post pictures yet? LOL.
04-23-2020 11:44 AM
Sure, up above is a "Share your Photos" section of the board. Note that if your images are full size out of the camera, you will have to shrink them a bit to fit the forum guidelines.
04-28-2020 11:26 AM
04-23-2020 12:04 PM
"Maybe I can post some to what you'll think?"
Please do.
Do you post edit at all? You need to for several reasons not just to be able to post on web forums but ti get the best out of each shot. You can d/l a good post editor from Canon. It is free and called DPP4.
Just like I advised to not over think simple shots, don't over do post editing. Sometimes less is more. You don't have to make something that is easy much harder but you can.
04-28-2020 11:26 AM
04-28-2020 11:54 AM
"don't you have to photos in Raw mode to use that?"
Whether you do or don't have to, you should. Raw format gives you a greater latitude of editing abilities than jpg does. Using jpg you are throwing away some of your cameras ability to capture all it can. Raw is a seamless format when you use DPP4 or Lightroom (preferred) editors.
If all you intend to do is send aunt Martha some email photos or post on the ole inner web, than jpg is just fine. But if you want the best quality, you need to use Raw.
