03-16-2020 10:33 AM
Camera : Canon EOS Rebel T6s
Files : RAW CR2 converted to Jpeg
Converter : CR2 converter
Problem :
CR2 files are downloaded from camera to PC, Windows 10 home 64b. 1909.
All images look normal in DPP.
But all the images appear reddish when converted to Jpeg by CR2 converter.
Please help to solve this issue.
Thank you.
Diano
03-19-2020 11:43 AM
"I usually download the CR2 files from camera to PC & convert then to Jpeg image Then I'll view the images with Windows Photo in large format."
If this is the extant of your routine there is no reason to use Raw CR2 format. The only advantage to folks that shoot Raw or CR2 is the ability to post edit. Actually a jpg right out of the camera can be as sharp or sharper than a Raw. In your case just jpg to begin with.
03-26-2020 10:30 AM
Thank you, Ebiggs1.
Usually, each of my shooting trip brings home any numbers of RAW file from 50 to a hundred shots.
The reason that I first view all the images in Jpeg format is to select only the good images for post editing in PS.
Again, thank you.
Dianoban
