03-16-2020 10:33 AM
Camera : Canon EOS Rebel T6s
Files : RAW CR2 converted to Jpeg
Converter : CR2 converter
Problem :
CR2 files are downloaded from camera to PC, Windows 10 home 64b. 1909.
All images look normal in DPP.
But all the images appear reddish when converted to Jpeg by CR2 converter.
Please help to solve this issue.
Thank you.
Diano
03-16-2020 10:53 AM
What do you mean by "CR2 Converter"? Is this a separate program or from DPP?
03-16-2020 11:24 AM
I have the same question as kvbarkley has. Canon has a software named CR2 converter, but that is for Canon EOS D2000 and its TIF raw files.
If you use DPP, which version do you use? Latest is 4.12 or 4.12.0.2.
03-16-2020 12:14 PM
Your Raw concerter can not convert T6s image files. Get a different post editor like Lightroom or Photoshop. Or, use the free came with the T6s camera, Canon's own DPP4.
03-19-2020 06:14 AM
Thank you, Kvbarkley.
CR2 Converter is an independent app, not included in DPP.
I usually download the CR2 files from camera to PC & convert then to Jpeg image. Then I'll view the images with Windows Photo in large format. Easy for me to save the good ones and delete the not so good one because all the images are viewed in size of full screen, 22 inches.
Again, thank you.
Dianoban
03-19-2020 06:40 AM
Thank you, Peter.
This is the second time I use CR2 converter.
Second time, not a second "time" but a second computer.
I have two desktop computers on my workbench, same brand & same model.
One (A) is used for photo editing and music, the other (B) is for general uses.
CR2 had been running on A for many years, no any issues.
A was deadlocked by Windows thee days ago, so, I used B for my photo editing.
CR2 was downloaded from the same source & installed on B the next day.
The app performed as smoothly on B as it was on A, but the reddish images.
Again, thank you.
Dianoban
03-19-2020 06:47 AM
Thank you, Ebiggs1 !
I have been using CR2 for years. The reddish issue happens only when I change computer.
And the two computers are of the same brand & same model & same OS, same everything but S/N's.
Again, thank you for your convern.
Dianoban
03-19-2020 09:20 AM
Who makes this CR2 Converter? You should take it up with them. If it is from Canon, where did you get it?
03-19-2020 10:03 AM
The CR2 converter I have downloaded and installed 2 times is downloaded from the site as the link hereunder:
03-19-2020 10:32 AM - edited 03-19-2020 10:34 AM
Then you will have to take it up with them. At least you got what you paid for. Frankly, I think you would be better off with something else that gives you more control. Why not save it directly from DPP? I think you can even batch it.
