07-08-2023 05:22 PM - last edited on 07-11-2023 08:38 AM by Danny
Dear community,
I am writing you to ask for your kind help.
I have Just bought a canon 5D mark 3.
And i wanted to use a Flash card.
Unfortunately, it looks like that i ordered a wrong one (a CF express Lexar Professional).
As i thought it was the good one, i tried to insert it on the camera... and now the card is blocked inside. (see picture below)
Can one of you please help me ? ...
I tried to remove it with a pair of tweezers but it did not work...
Did i need to open the camera? or can i do something else?...
Many many thanks ! .. really !
Matthieu
07-08-2023 06:08 PM - edited 07-08-2023 06:18 PM
I think that you will need to use a better tool than tweezers to grip the card. A pair of hemostats or needle nose pliers would grip the card better. You might do damage to the card though. Hopefully the camera card slot is not damaged. If so, it will need be repaired professionally. Once the card is removed, check the bottom of the CF card slot in the camera for bent pins. If it is damaged, you could just use the SD card slot.
If you get it out, you will need to use a Compact Flash (CF) memory card.
07-08-2023 07:10 PM
I would think you could get that out carefully and hopefully without damage to the card, slot or pins. I don't know if I would try to use anything that grips. Instead, I might try some automotive picks and be very, very gentle. Don't use any part of the body or slot as a wedge. It might be helpful to have someone hold or stabilize the body while you work on it,
Wishing you the best and luck with this one.
07-08-2023 10:04 PM
Matthieu,
Sorry to see your problem you're having. You'll have to weigh possibly damaging the card or taking it to a camera shop to have them remove the stuck card. I too would use either a hemostat or small needle nosed pliers, of course with the lightest pressure. Cut a piece of cardboard or thick paper so you can fold it over the card and grab it in the center or towards the right side in your photo. I know that card was probably expensive, hopefully you can get it out without damage.
07-09-2023 06:35 AM
Oh many thanks that works well , i manage to remove the card very gently !
Many thanks to you all for your kind message ! Merci merci!
07-09-2023 10:07 AM
Thats great news! Happy that both are intact without damage. 👍
