‎10-26-2023
01:37 AM
‎10-26-2023
08:11 AM
Just upgraded to a Canon R5. Using a Sony CFExpress type b card. Have no card reader at this time for that card.
Using an Intel (2019) MacBook Pro, OS 14. There is no Canon EOS utility for my computer/camera setup that I can find.
How can I transfer images to my MacBook Pro using the USB cable that came with the camera (or WIFI) without having Canon EOS utility available?
This is a but of a bummer!
‎10-26-2023 06:37 AM
Since you have a MacBook you can use the Apple Image Capture application.
You will probably get a permission pop-up when you connect the USB device.
‎10-27-2023 05:16 PM
Does the EOS Utility 3.17.2 not work? It doesn't list Mac OS 14 as being supported (I run Mac OS 13.5) but could be worth trying... https://www.usa.canon.com/support/p/eos-r5#idReference%3Dsoftware-drivers
‎10-27-2023 06:09 PM
Do your USB ports work?
‎10-28-2023 03:34 AM
Thanks! Does not seem to work on 14. Card reader comes soon then images will be able to go right to hard drive through Photo Mechanic Plus.
‎10-28-2023 03:35 AM
USB ports operate fine. Just did not see the R5 and didn't know to try Apple's Image Capture. Thanks!
