02-19-2025
04:21 AM
08:09 AM
Ken Rockwell writes:
To prevent the shutter speed from getting too long, many cameras (Nikon, Canon, LEICA M9, etc.) allow setting of the slowest sync speed in a menu.
But I am only able to find either 1/60-1/250 or 30"-1/250 on my R6. No option to set the slow sync limit to say 1/8. Flash is 580EXII.
Please help. Thank you.
02-22-2025 02:44 AM
The only way to limit the shutter speed to 1/8 with Av mode when using flash is…
Set the flash sync to 30” - 1/250 and also set the shutter speed limits to 1/8 as the slowest in the custom functions menu.
02-21-2025 09:02 PM
What mode on the top mode dial are you using. In Av (Aperture Priority) Mode the camera sets a slow sync automatically so there is no need for that setting. If you want to manually set a slow shutter speed use Tv (Shutter Priority) Mode or M Manual Mode. Note Fill Flash IS NOT used in Manual Mode. Instead Flash is treated as Main Light and NOT Fill Flash. This CANNOT be changed in the settings.
02-21-2025 11:06 PM
I am in Av mode. The slow sync shutter sometimes goes too slow like 1/2 or even slower. Would like to set limit to 1/8.
02-22-2025 02:44 AM
02-23-2025 12:12 AM
This works. Thank you.
