08-06-2015 10:56 PM
How the heck do I get my videos from my T6i onto my computer? I have the new software installed, I restarted my computer. The software seems to work fine when I open it but when I plug in my camera to my mac laptop nothing happens. It's not the USB (the port works with other devices). The camera is on, the Wi-Fi is enabled. But I can't get either a hard line connection or wi-fi between them. Even when I go to Applications > Utilities > System Information, my camera isn't there. So the computer definitely doesn't recognize it. I'm running OSX 10.9.5, Please help! I've tried googling about this all freaking day. Thank you!
08-08-2015 10:02 AM
08-07-2015 04:59 AM
Have you installed EOS ultility 3.2.21? Can be found here:
08-07-2015 09:25 AM
08-07-2015 01:21 PM
Thanks John. I tried just doing the direct dump from the SD card reader but it only worked for 1 video (not the other one), both show up in finder but after I import into iMovie, it says nothing is there (which I know is another problem all together). I'll try disconnecting the Wi-Fi and see if that works for direct connect. Thanks for the help!
08-07-2015 01:28 PM
If you open the SD card on the Mac and click on the movies can you get both of them to play (i.e. don't import to Mac)?
08-08-2015 10:02 AM
As stated if WiFi is enabled USB cable connection is disabled.
08-11-2015 02:17 AM
That worked! Thank you!
