05-13-2020 10:49 PM - edited 05-14-2020 01:35 PM
Is there anyway to remove the white rectangle on my Canon 5D Mark III?
I'm streaming a live yoga class into an Elgato HD60+ then into my MacBook Pro. I'm wondering if I need to do download the Magic Lantern firmware? I'd rather not do that if possible. Any suggestions? Thanks!
05-14-2020 10:16 PM
Paul9000,
You can try pressing the <INFO> button on the camera. Multiple button presses will change the on screen display until it eventually reaches a spot where it's blank and then back to full information display with several steps in between. This should change what you see onscreen as a result.
05-21-2020 12:24 PM
05-21-2020 12:31 PM
Hello, Paul9000.
The 5D Mark III does not offer clean HDMI out, however, we do have a new EOS Webcam Utility Beta Software that may allow you to stream via USB. You can learn more at canon.us/livestream
You will also see all of the current models that offer clean HDMI out.
If your camera isn't listed, be sure to sign up to be notified for future EOS Webcam Utility Software updates & releases, as our team is actively developing the software and will be adding more camera models in the future.
05-27-2020 01:51 PM
06-17-2020 06:47 PM
AF off | AF on.
No matter what, i see a box. From my camera through camlink.
SURELY there's a way to fix this in the settings.
Do I really need to downgrade to 1.2.3, then install magic lantern to get this done?
I'm currently on 1.3.6
( 5d mark III )
This is super annoying.
09-01-2020 09:24 AM
09-01-2020 09:25 AM
I finally did get the white box to go away, after installing Magic Lantern.
09-01-2020 09:25 AM
Typically, hit the info button and it'll go away.
09-01-2020 12:14 PM
Thank you! That worked!!! YAY!!!
