03-25-2022 05:26 PM
I would like to change the exposure bracket width on my R5 from one stop to two stops with my eye to the viewfinder. The only way I can find to do that is to use the menu. Is there any way to assign the exposure bracket to a dial or function? Thanks.
03-25-2022 09:05 PM - edited 03-25-2022 09:09 PM
I've been messing with this for a while, looking through menus and experimenting, and I would love to be wrong but I don't think it's doable. The best I've been able to do is assign Exposure Compensation to a button and move the whole AEB spread at once while AEB is active. The AEB spread doesn't show in the EVF when you add/subtract exposure using a back button, but you can see that the whole thing moves at once when you either look at the info on the LCD or go back to Exep.Comp./AEB in the main menu.
Newton
03-25-2022 09:18 PM
Thanks, Newton. That confirms what I have found so far.
03-26-2022 06:34 AM - edited 03-28-2022 01:05 AM
@HRBlock.com wrote:I would like to change the exposure bracket width on my R5 from one stop to two stops with my eye to the viewfinder. The only way I can find to do that is to use the menu. Is there any way to assign the exposure bracket to a dial or function? Thanks.
Before we delve into the camera menu, let’s first go over all the exterior controls. The Canon EOS R5 has many menu options, but there are some things that you can only do via specific buttons and controls.
