How Can I Recover/Repair .DAT file from Canon R6?
amillett
Hi! I have a .DAT file that resulted from my R6 freezing while shooting video of a wedding back in October. I've tried using different software that had little to no results (VLC, Winff, Stellar Repair) and wanted to reach out to the community with any suggestions of what can be done to recover the video from the file. It shows data is in the file (448MB), but I can't view in camera or on my computer. Thanks!
14 REPLIES 14
nicholastjs
I have the same issue after taking an overnight timelapse. Wondering if anyone can share any ideas on how to recover the DAT file.
rs-eos
I would have thought that the extension would be something like "MXF" instead of "DAT". A long shot here, but what happens if you rename to use an "MXF" extension instead?
Or better yet, locate any valid video you captured beforehand and note its extension.
Ricky
nicholastjs
Typically all video and timelapses taken are MP4. However, there's one file that has DAT as its extension, which I believe is due to some corruption, but the file is still 260MB. So I would like to see if there's a way to recover this.
Kong
Anyone know if the Stellar Repair for Video works? It's $70 for the unlimited version. I don't want to buy it if it is pointless. There are some You tube videos promoting it but I noticed that Amazon has this and the ratings are horrible. I am not going to buy it unless someone can vouch for it . Or other products? I am surprised Canon does not have a patch for this.
They offer a free trial download. You could check it out for yourself.
Hey! I did try changing the file type, but unfortunately that didn't make it playable either 😞
Hey Kong, I tried it, but it didn't work - I had success with aero quartet, but they will charge you (for me it was $49 for my small 16 second clip)
I just used their service, but as you mentioned, their $49 for any video seems a bit too pricey for short clips. I paid $49 for a 5 second timelapse video 😞
Many SD / CFExpress card manufacturers offer file recovery software. Some are free, some paid. I've used Test Disk and PhotoRec by CG Security. Note this is a free utility, but command line based. Others are below.
$49 is inexpensive compared to losing your reputation with a paying client. Lexar, ProGrade, and Angelbird all have recovery tools as well.
