06-15-2016 12:05 AM
All of the settings on our DSLR (apperture, shutter speed, etc.) got all messed up and I'm wondering if there's any way to reset the entire thing?
06-15-2016 04:09 PM
Taking out both batteries worked. Got some of the settings reset, but some are due to other things wrong with the camera. I'm gonna need to take it into a shop somewhere to get it all fixed up. Thanks all for the help!
06-15-2016 09:46 AM
Check your "wrench" menus, there is a reset camera option there.
06-15-2016 09:48 AM
Take the batteries out for about 30 min. There are two and both must be removed for an extended time period. It will reset back to factory defaults. If you have to re-enter the correct date and time, the camera did reset itself.
06-15-2016 01:34 PM
@ebiggs1 wrote:Take the batteries out for about 30 min. There are two and both must be removed for an extended time period. It will reset back to factory defaults. If you have to re-enter the correct date and time, the camera did reset itself.
I don't quite follow that. I've always been led to believe that the reason for leaving the (main) battery out for an extended period is to force a discharge of the built-in date/time battery. Now I've never seen a 20D, but I did have occasion to work on a 10D the other day. And if the 20D is like the 10D (as your instruction above suggests), its date/time battery is removable. So shouldn't removing both batteries kill the settings immediately, obviating the need for the extended time period?
06-15-2016 02:59 PM
It's possible that there is circuit to temporarilry maintain a charge on the clock, and other essential circuitry, so that you can change out the battery without resetting the device.
06-15-2016 04:09 PM
06-15-2016 04:53 PM
Bob from Boston,
"... obviating the need for the extended time period?"
No it doesn't but it probably doesn't take a full 30 minutes either. That is simply a safe number to make sure all the capacitors are drained.
