11-09-2023 02:58 PM
I have owned an EOS mirrorless R6 camera for 3 years. About two weeks ago, I noticed all my images displayed a green dashed line on all my images. This green line runs vertically from top to bottom, about 1/5 of the way from left to right. I have tried different settings (changing shutter speed, aperture, ISO, etc.). Still shows green line.
However, I switched to cropped frame and I don't see the green line anymore. Is this a sensor issue? I would like suggestions for a fix.
11-10-2023 02:17 PM
One thing lot of photographers are unaware of is laser/lidar damage to sensor (i.e. taking picture of concert with laser show or taking a picture of self driving car with lidar system). This definitely looks like a damaged sensor.
You'll likely need to send the body into Canon for repair. By using crop frame, the image area will zoom into the center of the sensor and avoid the green line. As it's out of warranty, it won't be a cheap fix but cheaper than a new/used body. So your options are:
11-09-2023 03:09 PM
Yes, it could be a sensor issue. Take a photo with the lens cap in place.
11-09-2023 05:11 PM
Share some raw files, including the cropped frame.
11-09-2023 09:45 PM
11-09-2023 09:47 PM
The green line appears more like 1/8th in from the left. Image is the full frame.
11-10-2023 01:16 AM - edited 11-10-2023 03:14 AM
I can barely notice it viewing a low resolution picture. A line like that may indicate that a whole row is dead and that the camera needs a repair. For already taken raw files you can create a bad pixel list for RawTherapee and perhaps the fork AnotherRawTherapee, see the workaround for the laser damaged R6 https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/Pink-line-on-all-R6-images/m-p/401100
Read my previous comment again about sharing raw files if you want a better answer.
11-10-2023 02:17 PM
11-10-2023 04:58 PM
11-10-2023 09:54 PM
I was afraid of that. I have been able to save some of the damaged images, so I'll stick with the post processing solution for now. Thanks for your response. I will definitely consider all your suggestions.
