06-20-2021 11:32 AM
I have an EOS 7D which numbers I guess by the body count (curent frame no = _0015384) When I use the internal flash the numbering system changes the '_' to an 'A'. Why does it do this and can I stop it doing it? Also can I stop it using the '_' altogether?
06-20-2021 04:04 PM
The underscore is being caused by the fact that you must have "Adobe" color space selected, instead of the factory default.
06-21-2021 10:54 AM
So why does the underscore change to 'A' on some flash photos but not all?
06-21-2021 11:55 AM
It is because you shoot in AdobeRGB. It is a requirement of the DCF 2.0 specification. Canon simply chooses to use the same naming convention for its Raw files to keep things simpatico. If it bothers you try using SRGB. Otherwise LR and Bridge allows batch file name renaming. And, you can set color space there also.
06-21-2021 11:57 AM
From the Canon manual
"Set [
: Color space] to [sRGB]. If [Adobe RGB] is set, the first character will be an underscore."
06-21-2021 07:11 PM
@APIMan wrote:So why does the underscore change to 'A' on some flash photos but not all?
The discussion about Adobe RGB and the underscore is an industryu standard - not unique to Canon.
I have never seen the "A" prefix show up on my flash photos; not sure what is going on there.
06-22-2021 09:38 AM
"I have never seen the "A" prefix show up on my flash photos ..."
Neither have I.
07-05-2021 07:32 AM
