04-28-2022 12:18 PM
True or false...............
04-28-2022 12:37 PM - edited 04-28-2022 12:51 PM
What camera do you have and what shooting mode?
I never noticed the phenomena you are describing, but just now did a deliberate test measuring exposure with External Speedlite control menu setting to enable and disable. No change in calculated exposure for the camera.
My camera does not have a built-in flash.
Tried with and without external Speedlite installed (powered off). Same results.
04-28-2022 12:46 PM
A little confusing, did you or did you not have a flash no matter where it was in use at the time? A dedicated flash sends out a signal to help determine settings.
04-28-2022 12:50 PM
It was referenced from an individual on the subject. I own the R, R6 & R5 and have noticed nothing. I thought I would pose the question to others to see if there was any possibility of this.
04-28-2022 12:54 PM
OK. Understood. Without knowing exactly what the other person was doing it's hard to say why he observed what he reports.
Your experience is what I saw and would expect.
04-28-2022 12:59 PM
I think hes confusing the menu settings as opposed to the flash being on or off and changing the histogram.
