08-01-2019 12:05 PM - edited 08-01-2019 12:21 PM
When I try to pair my EOS Rebel SL2 with my laptop via the Canon EOS Utility, I get a message saying that "To connect to the camera via LAN, some Windows Firewall settings must be changed."
I called Canon technical support to find out exactly what Firewall settings need to be changed, and they could not help. They directed me to this forum.
Does anyone know exactly what are the Windows Firewall changes that need to be made to pair/connect the camera to my laptop?
Thank you
08-01-2019 02:27 PM
@ldarango wrote:When I try to pair my EOS Rebel SL2 with my laptop via the Canon EOS Utility, I get a message saying that "To connect to the camera via LAN, some Windows Firewall settings must be changed."
Thank you
I assume that for some reason the connection has to be wireless. Because if it doesn't, you're just making things more difficult than they need to be. A wired connection uses the USB protocol, which makes the camera look like a disk drive and bypasses the Windows Firewall altogether. Or you can use a USB card reader, which simplifies the process even more.
08-02-2019 10:32 AM - edited 08-02-2019 11:15 PM
Here are your steps
Firewall setting
Allow an app through the FW
Change settings button
Allow another app
Browse
Then navigate to EOS Utility Folder
Select the .exe you want to allow
Note: The one you need is likely in the EU2 or EU3 folder depending on which camera you are using. Once its added to the last of allowed apps, you can check the boxes for the correct Network type, Public, Private or Domain
You are probably private. Don't worry if you make a mistake, all of these changes can be removed or modified at will.
08-01-2019 02:27 PM
Thank you
08-01-2019 04:20 PM
Thank you, Bob.
The connection does not have to be wireless (Wi-Fi), since the primary reason for the connection is to get access to the pictures. I understand that access can also be obtained via USB and SD card reader.
However, the camera is promoted to have connection via Wi-Fi and I wanted to take advantage and explore its capabilities via the EOS Utility application.
Lou
08-01-2019 07:38 PM - edited 08-01-2019 07:39 PM
Lou,
I use ethernet for my 1DX bodies but for WiFi you are going to need to go into Win 10 settings, choose windows security and then firewall and network protection. That will pop up a new window and one of the options in this window allows you to choose which apps can get through the firewall and you will need to give access to whatever Canon app is being used to connect via wifi.
I am using Win 10 64 bit pro on my machines but I suspect home edition has the same sequence for firewall configuration.
You will need to be signed in as an administrator to make these changes.
Rodger
Here are your steps
Firewall setting
Allow another app
Browse
08-02-2019 12:19 PM
Thanks Rodger, this makes sense.
08-02-2019 12:20 PM
Thanks Rick, for the details. I'll try when I get a moment.
08-02-2019 01:12 PM
The program that needs to be allowed for my camera is under C:\Program Files (x86)\Canon\EOS Utility\EOSUPNPSV.exe
I'm good for now. Thanks to all for your help!
Lou
