10-18-2022
11:14 AM
09:44 AM
fyi, I just discovered that autofocus is achieved much more reliably in a room with standard recessed lighting at night with the flexible lens hood extended on EOS RP w/ EF 50mm f/1.4 USM.
10-19-2022 10:36 AM
Hmm, I find that odd but interesting. I suspect it is a situation advantage VS a true AF improving condition. I almost always recommend folks use a hood. It can help reduce and/or eliminate side light or reflections from entering the lens.
10-19-2022 09:20 AM
Interesting as I will be doing some indoor photos for basketball games. Will try it. Thanks.
10-19-2022 10:36 AM
