Can't use vintage lenses on m50 mark ii
Divad
I can't access the custom functions setting. I don't even have the page it should be one (page 5). Can someone help me with this? I looked at the firmware update and it doesn't talk about it. The mark ii not the mark i
3 REPLIES 3
Tronhard
VIP
VIP
Hi and welcome to the forum
When you say you cannot see the page it should be on, which mode is the camera set to.  You will not see all the menu options in the P and Auto modes.  Set the camera to Av, Tv or M mode to see all the pages.
cheers, TREVOR
amfoto1
When you write "vintage lenses" are you referring to vintage manual focus, manual aperture lenses without any electronic communication or to older EF mount lenses with electronic AF and aperture (either of which can be adapted to use on EF-M mount cameras)?
If it's the older manual focus/manual aperture type of lens, you have to set "allow shutter to fire without lens on camera" in the menu to use them. The reason is because the lens has no electronic communication with the camera,so  the camera doesn't "know" a lens is installed, By default, the camera is designed to not allow the shutter to be fired without a lens, so this override is needed. Setting it to allow the shutter to work doesn't change anything when using the camera with more modern lenses that have the electronic communication (both lenses in EF-M mount and adapted EF-mount lenses).
Incidentally, there are also modern lenses that are manual focus/manual aperture, that require this menu setting to allow camera to "shoot without lens".
Finally, when using any lens without electronic aperture control, you will have limited use of the exposure modes. "M" or fully manual mode will work, of course. "M + Auto ISO" also should work. "Av" or aperture priority mode also should work. Experiment with them on your camera to see if they work okay. But, "P" (program) and "Tv" (shutter priority) will not. Both of those require the camera have means of setting the lens aperture, which it doesn't with this type of lens. The "scene modes" such as "sports", "landscape", "portrait", etc. will probably also not work. (I honestly don't know because I never use them).
Hope this helps!
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5 and some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
Hi Alan:
Totally agree with you. It seems that Divad can't see the menu, and I suspect that is because he is not using a suitable mode to be able to see the full menus.   He has been advised, so I guess we wait and see if he responds...
cheers, TREVOR
