01-13-2020 12:37 AM
Hello
New to Canon as my 6D MK2 is my first Canon and only had since Xmas.
Having real problems with my photo's being less than satisfactory.I just cant get anything crisp
example as below,settings are
ISO-160
F5.6
1/400 - Aperture priority mode
single focus point and on auto.
subject about 4Metres away with Canon 100-400 lens set to max.
any advise would be greatly appreciated.
David
01-13-2020 10:05 AM
Looks to me like the lens is front focusing because the sharpest point is the dirt in the foreground. Use the micro AF adjust procedure in the manual to dial in the focus. I use a slightly different process to quickly dial in a new lens and during setup I shoot three frames at several adjustments each side of 0 which lets me quickly zero in on the exact point.
Also use as much shutter speed as you can, IS helps but when light permits I prefer going with shutter over IS.
Rodger
01-13-2020 10:05 AM
"any advise would be greatly appreciated."
Of course!
"subject about 4Metres away with Canon 100-400 lens set to max."
What does that mean, set to max?
"ISO-160
F5.6
single focus point and on auto."
Your setting are not horrible but not great either. If you were using Av than you need more ISO to get the SS up to 1/1000+.
Av
ISO 400+
f5.6
1/1000 is now possible.
When I do photography like you were trying to do I almost never let the ISO go below 400 and use ISO 800 a lot even more sometimes. This keeps the SS up where it needs to be for long tele lenses.
Another possibility you just missed focus but more likely you let the camera move because the SS was too slow. Two things to keep in mind, 400mm hand held isn't easy and requires practice to get good at it. Second 100% crop will show every mistake, every little thing.
01-13-2020 10:12 AM
" Use the micro AF adjust procedure in the manual to dial in the focus."
This is possible but at this point, a new to photography person, don't do this a s a first thought solution. It can do more harm than good if you don't fully understand it. Adjust your settings as suggested, higher ISO and Av lens set to f5.6 and practice, practice practice.
BTW, use One shot and just the center point. Turn the others off.
01-13-2020 10:15 AM - edited 01-13-2020 10:17 AM
A couple of the guys who post regularly here have this lens. I don't, but know its well liked.
What I see, it looks like the lens front focused in the image and didn't capture the intended subject.
Normally, we tell people to capture more than one photo and with different settings. A hand held shot at full zoom even with IS and 1/400 might not be as sharp as a one shot with Av at f8 or more and with a tripod.
Try taking sets of 3 shots with different settings. This will make it easier when evaluating your images.
**Edit, everyone has beat me to it... what I get for making coffee....
01-13-2020 11:43 AM
Rick wrote:
"**Edit, everyone has beat me to it... what I get for making coffee.... "
I learned long ago not to respond to questions without first making and consuming coffee Or as an old college prof used to quip, the early bird may get the worm OR that early bird might mistake cat excrement for a worm if not fully awake 🙂
And I agree with KV about focus point(s), any image with a focus question needs to include those.
Rodger
01-13-2020 12:47 PM - edited 01-13-2020 12:51 PM
DPP reports focus point on bird.
EXIF data reports AI Servo. In my experience that can sometimes cause problems if subject isn't really moving. There isn't a true focus lock and camera shake can be confused as subject motion.
01-13-2020 01:06 PM
If not used properly and understood properly Ai-servo can cause lots of problems. Use One shot until you fully understand your gear. Keep the more advanced stuff for later as you become more familiar how stuff works.
01-13-2020 11:09 AM - edited 01-13-2020 11:10 AM
Can you show us the image with the focus points highlighted? I think that will be just as instructive for you as us.
As Shadowsports said, it looks like it focused on the rock in front of the bird.
AF will focus on the closest thing in one of the selected focus points.
01-13-2020 01:06 PM
